Old 07-20-2010, 08:38 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Epoxy/sealer for carb inlet fitting to bowl
Racers,
Please recommend an epoxy/sealer that I can use to permanently seal/bond fuel inlet fittings into Holley float bowl.
Thanks
Old 07-20-2010, 08:43 PM   #2
Chad Rhodes
Default Re: Epoxy/sealer for carb inlet fitting to bowl
Good ole JB weld
Chad Rhodes 2113 I/SA
Old 07-20-2010, 08:54 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
JB Weld it is - just let it cure really good before you use the carb.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-23-2010, 10:10 PM   #4
Danny Ashley
Liked 110 Times in 29 Posts
Larry:
I tried to respond to your PM but it said you do not receive them and wouldn't sent it through. I use a product called MT-13 from Smooth-On.com. It was recommended to me by a gentleman that used to work for Rochester and now restores carburetors. He simply hates JB Weld. I repaired a friends Q-Jet the other day exactly the way you are wanting to do the Holley and I felt very good about the finished product. It's expensive but sounds like that carb is worth it. Good luck. Danny
Danny Ashley is offline   Reply With Quote
Old 07-24-2010, 08:48 AM   #5
BlueOval Ralph
Banned
Danny is right MT-13 is very very good it also woks well in cylnder heads and Intake as a filler.
Originally Posted by Danny Ashley View Post
Larry:
BlueOval Ralph is offline   Reply With Quote
