Old 07-03-2010, 05:34 PM   #1
rod
Liked 20 Times in 15 Posts
Default cam timing ?
cam timing figures show the cam is ground at 4 degrees advance.
my questions are: if i install the cam straight up [0] is the cam now advanced 4 degrees or is it 0. if i physically move the cam to 4 degrees advance, is it now 8 degrees advanced or 4 degrees advanced?
i've got all the other numbers figured out and under control except this on issue.
thanks
rod in AZ
rod is offline   Reply With Quote
