Old 07-02-2010, 07:25 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Weight vs ET
If you lightened a car 150 lbs what would the ave gain in ET be???
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 07-02-2010, 07:34 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
Default Re: Weight vs ET
The approximate number has always been a tenth per hundred pounds, but there are variables of course....I always use the Wallace Calculators for quick reference and know many others do as well; here's the link
http://www.wallaceracing.com/Calculators.htm
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-02-2010, 09:06 AM   #3
Ed Carpenter
I used following data on wallace
ET 10.05
MPH 130.00 at 3050lbs
wallace says at 2900 lbs
ET 9.88
MPH 132 and change
Ok why then does NHRA list SS/G at 10.45 index SS/H at 10.50 SS/I at 10.55 etc
difference in weight from H to I is 150lbs yet only 5 between indexes????????????
Ed Carpenter
Old 07-02-2010, 09:13 AM   #4
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Because physics didn't create the index system.
In my 4-cyl FWD car, 215 pounds was nearly HALF A SECOND, in the 1/8th mile! If I recall, a similar change in my Volare was about .12 in the 1/8th.
Old 07-02-2010, 09:30 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Good answer Michael.... Index system was created by Man and then hit/altered by man and his race cars performance!
Adger Smith (Former SS)
Old 07-02-2010, 08:28 PM   #6
JRyan
Liked 112 Times in 31 Posts
Ed, the REAL reason stems from way back and the answer is two words: Danny Helmer.
Jerry
Old 07-02-2010, 10:33 PM   #7
Jeff Lee
Jeff Lee's Avatar
Jerry
From everything I have been told, that is correct. Before AHFS, HP and or index was adjusted heavily when one racer dominated.
I can run SS/G-H-I just like you. Kind of makes it a difficult decision which to run, huh?
Jeff Lee 7494 D/S '70 AMX
Old 07-02-2010, 10:44 PM   #8
Ed Carpenter
Jeff it doesn't make sense. H is at 3010. Why in the hell would you add 150 to get to I at 3160. So one guy was fast why did it effect all the indexes. Why didn't they hammer his combo? That's what they did to Robin Brown with the 283 stick in 07'
Ed Carpenter
Old 07-03-2010, 10:30 AM   #9
Jeff Lee
Jeff Lee's Avatar
I guess that's just the way it is. Why don't you contact NHRA and see what can be done about it? Call NHRA Tech and ask for Pat Cvengros as he's the Committee Chairman of the S/SS Rules Committee.
Seriously, nothing will come of this posting here, you have to go to the source.
While your at it, get the stick indexes in line with the automatic indexes. For example, there's a .200 spread between SS/J & SS/JA. That's ridiculous!
Old 07-03-2010, 06:12 PM   #10
Ed Carpenter
Jeff I did send a letter to NHRA a couple of years ago. They basically said to pound sand. My car needs to get the 299hp reduced. IHRA is 295hp. The 327/275 combo has been beat on for over 30 years. There's not alot left to be found in the horsepower dept. Were going to try a set of the RHS aftermarket heads this winter. But guess what the hp rating goes up to 304 when you do that. So well see.
Ed Carpenter
