Old 06-30-2010, 09:37 AM   #1
Mike Fuller
Liked 198 Times in 79 Posts
Default New Holley replacment carb.
I dont see this posted anywhere on NHRA's site. Is this info correct?
Travis, what do you know about this?
http://www.competitionplus.com/index...-stockss-legal
Mike Fuller 396 STK
3961 SS
Old 06-30-2010, 09:43 AM   #2
SSDiv6
Liked 1,577 Times in 581 Posts
Default Re: New Holley replacment carb.
Interesting...if anyone was to make the same modifications to their current Holly carb, they would be tossed immediately.
Old 06-30-2010, 10:09 AM   #3
LXguy
The carb pictured is from their Hot Rod series I believe. I don't know what the actual carb discussed in the article looks like.
I'd have to assume it doesn't really have screw in bleeds or an aluminum body!
LXguy is offline   Reply With Quote
Old 06-30-2010, 10:45 AM   #4
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Or the 4 corner idle system...Well, depending on who you are, you can get away with it on your current setup...Maybe its who you know in tech when they look at the carb?
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 06-30-2010, 11:28 AM   #5
Woodro Josey
Liked 3 Times in 1 Post
This Carburator does have the screw in air bleeds and Technically not 4 corner idol. If you have any questions about this Carb, call Phillip Vickous at
270-793-0900. Thanks
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 06-30-2010, 11:51 AM   #6
Duane Eiskant II
Woodro, what do they do? get it close cut the screws off and silicone over the holes? LOL
Duane Eiskant
Old 07-01-2010, 07:23 PM   #7
vic guilmino
Liked 56 Times in 21 Posts
where is this on the nhra page
Vic Guilmino 1129 STK
Old 07-02-2010, 09:07 AM   #8
LXguy
So, just to clarify...
I get to dig through junkpiles and Ebay looking for a one-year-only POS Rochester 2bbl, and then try to figure out how to make it work, and what I can and can't do to it, but there's some combination that can just call up Quickfuel and order up a new-tech brandy new aluminum carb?
That seems pretty whack to me. I'm just sayin'.
PS Not faulting Quickfuel, they make awesome stuff.
Old 07-02-2010, 11:15 AM   #9
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
LX you do know you do not need to run the right # carb dont you ? can be any # as long as it is the proper cfm and the throttle plates measures the same as original.
Bob Pagano A/SA
Old 07-02-2010, 12:55 PM   #10
LXguy
Bob:
I did not know that. Thanks!
I'm sure that will make the task easier. Does NHRA have those measurements somewhere?
Steve
