Old 06-22-2010, 09:30 AM   #1
COPPERN
Default C4 tranny problem ?
Had my c4 rebuilt and the car won't accelerate past 5000 rpm in first gear second and third it goes to 7500 rpm no problem.
Sixty foot times are also way off normally low 1.50 now 2.00 any ideas.
THANKS.
COPPERN is offline   Reply With Quote
Old 06-22-2010, 10:58 AM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: C4 tranny problem ?
Check the intermediate band adjustment. If it's too tight it will drag badly on the high gear drum that is turning about 85% of the input RPM, but the opposite direction.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 06-22-2010, 09:39 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Sounds like the high gear clutches are centrifugally applying in first gear. This could be caused by trapped oil behind the high gear piston, or a cross leak into the high gear clutch circuit.
Old 06-23-2010, 12:09 AM   #4
COPPERN
Bill and ss3011 thanks for your replies
