Old 06-21-2010, 03:47 PM   #1
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default Nasty Vibration
The Monte has developed a very bad vibration in high gear. Changed driveshafts and the problem seemed to lessen temporarily, but it's back as bad as before. The driveshaft is straight. Dad can barely hold the shifter back in 4th as he crosses the finish line. We are taking the tranny apart to see if the mainshaft is bent or ???. Can a ring gear be out of balance? We are sending the clutch and disk away to get balanced. Axles ???.
Any help would be appreciated as we're really scratching our heads on this one.
Many thanks in advance!!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 06-21-2010, 04:36 PM   #2
W J
Default Re: Nasty Vibration
Just random thoughts, but 1, Make sure rear hasn't moved (string-measure both sides, center of front whl. to center of back whl.) 2, Pinion bearing going bad, or something moved inside rear? Good luck....WJ
Old 06-21-2010, 04:40 PM   #3
RPinoski1
Might have lost a wheel weight or two???????
RPinoski1 is offline   Reply With Quote
Old 06-21-2010, 04:50 PM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
Several years ago, I had a front wheel/tire out of balance at Scribner that caused my vision to blur so bad that I could not see the scoreboards.
It shook everything in the car.
I had Joe Archer re-balance and cleared it up.
Old 06-21-2010, 07:56 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Rear bushing in tranny or main shaft bearing.
Adger Smith (Former SS)
Old 06-21-2010, 08:08 PM   #6
Darrin Christen
Darrin Christen's Avatar
Had a similar problem years ago. I had the drive shaft rebalanced, changed the bushing in the trans tail shaft housing, and also had the front and rear wheels rebalanced. Problem was still there, bad vibration about the last 300' of the track. Ended up breaking the trans case across the bell housing. I put a new Dedenbear trans case in the car and the problems was still there. By this time the rear tires needed replacing and bingo the problem went away. Smooth as glass with the new tires. Before this problem started the car had sat in the garage for two months while freshing the engine. I had neglected to put the car up on jack stands and I guess the rear tires got flat spots. Won't make that mistake again.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 06-21-2010, 09:55 PM   #7
Stephen & Horace Johnson
Liked 165 Times in 54 Posts
I had the same issue on my 5speed mustang, it would vibrate so bad that it would jump out of gear as soon as i pulled into gear. It was my mainshaft that was bent. I took it to work and put it on jig and realize it was bent!!! I junked it and put a new one in, and never had the problem again.
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is online now   Reply With Quote
Old 06-21-2010, 09:57 PM   #8
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Mike I had the same thing last year. I could not hold the shifter in high gear. Pilot bearing came out in pieces when we dropped the can. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-21-2010, 10:00 PM   #9
Tracy Robbins
Liked 25 Times in 11 Posts
I had a similar situation when a couple of bell housing bolts had backed out earlier this year, sounds simple but it can happen.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 06-22-2010, 09:16 AM   #10
Mike Voth
Mike Voth's Avatar
Housing is centered. Pinion bearing feels good and rotates smooth, but 3rd member is coming out tonight, so we'll see. Thanks
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
