Old 06-04-2010, 06:52 AM   #1
lt4race
Default Cavalier radiator
Does anyone have any suggestions on where to purchase a radiator to cool a 350 LT1 reverse flow engine in a Superstock cavalier.Block is filled and engine overheats quickly with stock rad first time out. Stock rad core is 16 x 26 and 31 inches wide with tanks. LT1 Camaro is too wide. I would like to be able to hot lap. Thanks, Chester Fincke SS 1019 Email lt4race@yahoo.com
1019 STK SS STICK RACER, Chester A. Fincke
lt4race is offline   Reply With Quote
Old 06-08-2010, 09:10 AM   #2
njk53
Default Re: Cavalier radiator
Before you change the radiator a few questions: Are you running a fan? Fan Shroud? Did you check the pulley ratio? Fan out of shroud measurement? Using a thermostat or restrictor? Baffles in front of the radiator?
Nelson Kowal
Stock 345
Old 06-09-2010, 04:32 AM   #3
al wisniewski
Contact Kirk At BeCool in Essexville Mich. I believe they have a bolt in for your car.
al wisniewski is offline   Reply With Quote
Old 06-09-2010, 06:23 AM   #4
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Chester, I use an electric fan and custom built aluminum shroud. You can PM me for more info. This is what I'm using in my 60 Corvette. Wade
Wade Mahaffey is offline   Reply With Quote
Old 06-10-2010, 04:59 AM   #5
lt4race
Thanks a lot for your responses, I have removed the stock 14 in fan and shroud. I have installed twin 11 in 1000 cfm fans directly on the core but have tested yet. Chester
Old 06-10-2010, 08:20 AM   #6
Aaron Allison
Liked 150 Times in 43 Posts
I would try the stock radiator with the new fans before you purchase a new one. I currently run the OE radiator in my SS/BM cavalier and dont have any problems. I did have it cleaned out a few years ago and that seemed to help.
Aaron Allison 395 STK, 395 SS, 3395 SC
Aaron Allison is offline   Reply With Quote
