Old 04-11-2010, 01:01 PM   #1
langtown
Default Carb help
Hi everyone I'm back for some more help. I have a 1967 Camaro with a 327 the cam duration is 239in 246ex @ 50 lift .484in .478ex lobe sep 108 and 462 heads. Trans is a th350 and stalls at 3400. Rear end has a 3.90 gear ratio for the street and a 5.13 for track days. I need help with carb selection. I did the C.I.D. x max rpm/3456 x V.E. formula and came up with needing just under 600 cfm do you think I need a bigger carb than that. Im open to all suggestions thanks a lot for taking time to help.
langtown is offline   Reply With Quote
Old 04-11-2010, 05:41 PM   #2
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Default Re: Carb help
I am thinking a 750 is a good choice. I think anything smaller than a 650 would be to small.
I ran a 650 for years ona similar combo, never did get a chance to try the bigger carb although I suspect it would have been worth some improvement.
Just one man's opinion and worth exactly what you paid for it.
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
