Liked 287 Times in 153 Posts
Have a 2000 Ford F250 pick up with the 7.3 Diesel----All of a sudden the truck is howling like made ---sounds like its coming from the turbo-NO POWER but not blowing heavy black smoke---what is wrong and how much to fix it??? Any ideas ??? 97000 miles always taken care of no abuse---- NO MODS to truck totally stock ---thanx Comp 387
Liked 461 Times in 61 Posts
Not an expert here (or any where for that matter), but I did have a gasket blow on the pressure outlet of the turbo on a previous motorhome which gave us the same indications.
PS. I did stay at a Holiday Inn Express once. |
#3 | |
Liked 472 Times in 115 Posts
Eric
Eric Merryfield 1883 STK |
Liked 44 Times in 22 Posts
If you need a turbo, you will probably save a lot and get a better unit from High Tech Turbo in Utah vs. stock from the dealer. Change the oil and be sure no metal bits went into the pipes and intercooler.
#5 | |
Liked 7 Times in 4 Posts
the bolts holding the turbo section together did not back out and fall on top of the intake, You will need to climb way up on top and as far back as you can see to make sure all the bolts are still there. Also buy a spare Cam sensor and throw it the glove box with a 10mm socket and ratchet it will save your _ _ S one day... Hope this helps. A&M motorsports Bob Aceves #746 E/SA
Bob Aceves, 746 E/SA A&M motorsports |
Take a look through this forum. It has helped me a number of times.
http://www.thedieselstop.com/forums/
Art Leong 2095 SS |
