Old 03-26-2010, 07:32 AM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 889 Times in 239 Posts
Default Copper head gasket sealers
Since my favorite silicone sealer [ red differential ] is no longer available from Mopar, and It was the best of any sealers I tried over the years, What have you found to work for you ?..........I've used Hylomar , Permatex Super 300, spray on sealers, all of which worked to varying degrees, but none performed as well as the Mopar sealer. .........I have not found it's equal in the aftermarket. .......Open to suggestions, BTW the gaskets I'm sealing are .080" thick,so strength at higher mill thickness is important ,since the gasket has a harder time conforming to the surface. .....Thanks , Tom
