Old 03-23-2010, 03:32 PM   #1
ericsz
Default 350 Turbo Issues...
350 Turbo with Pro Brake. Just installed new tranny and button, I know the button works properly because I have to push it in order to go into reverse. I pull the shifter (Reverse Pattern) back into low gear up on jack stands and let it roll and works just fine, same with 2nd gear, when I pull it down to 3rd it makes about 5 revs then locks up. The transbrake button will not hold the car either, Press the brake push the button let off the brake and the car rolls.....Any ideas?
Eric Bowling
ericsz is offline   Reply With Quote
