Old 03-17-2010, 11:01 AM   #1
phillip wigington
phillip wigington's Avatar
Default fuel pump of choice"?
just curious? what is your fuel pump of choice! i run a bracket truck and have been having issues with the fuel pressure down track. its fine in low gear and when i shift to high gear it seems to POP! when under a load. like a lean out situation. i dont have a pressure gage visable while driving YET!!! lol i run 7.25 lbs at regulator and have checked everything under the sun so far... valves, fuel jets, timming, coil, any suggestions?? remember its only in high gear! even in the burn out. thanks DOES THIS SEEM TO BE A FUEL PRESSURE OR VOLUME ISSUE TO YOU? thanks phillip
Some days your the dog! Most days your the hydrant!.
phillip wigington is offline   Reply With Quote
