Old 03-16-2010, 07:17 PM   #1
362ciNova
Default Suspension Question
Hey guys. I have a 72' Nova and ive been having alot of problems getting it to launch, and was wondering if anyone had any advice on how to set it up. I currently have monoleaf springs, slide-a-links and QA1 drag shocks. i set the traction bars up just like the directions said, and i got it running consistant 1.60 on my 60', but i switched my tires from mickey thompson drag radials to hoosier qtp's, and i cant get it to stop wheel hopping. ive played with the tire pressure, shocks, and reset my traction bars, and nothing helps. i cant seem to get lower than a 1.68 or so on my 60'. If anyone has any tips or advice im all ears.
362ciNova is offline   Reply With Quote
Old 03-19-2010, 08:50 PM   #2
Alan Sargent
Alan Sargent's Avatar
Default Re: Suspension Question
The Hoosier's might have too soft a compound for the weight of the car.
Alan Sargent is offline   Reply With Quote
Old 03-21-2010, 11:23 AM   #3
tpoh815
tpoh815's Avatar
Liked 28 Times in 11 Posts
Thumbs up Re: Suspension Question
Go back to the Mickeys and see if it works again, then you have piece of mind!
EX 5-Doorstocker
tpoh815 is offline   Reply With Quote
Old 03-23-2010, 06:51 PM   #4
Mile High
How much air? I wouldn't go less than 14psi. The slide-a-links I'd tighten up, no gap on the cushions. Loosen the shocks let them stretch out. A friend has a 72 Nova with split mono leaf suspension and slide-a-links. Using Hoosier DOT radials and loves them. Sixty foot numbers are low 1.60's.
Mile High is offline   Reply With Quote
Old 03-26-2010, 08:31 PM   #5
Mile High
I talked to my Nova friend you maybe stretching the shocks completely out and unloading the rear suspension. He put on extensions on the shocks and fixed his car.
Old 03-28-2010, 12:11 PM   #6
Theo
Theo's Avatar
I use calvert Split Mono Leaf 2000 200lb. - 225lb. spring rates available.and a four link set up witch is not ajustable and I use Competition Engineering's ANTI-ROLL BAR Universal Application (C2041)that i custom fit to the frame also a set of Competition Engineering's 3-Way Adjustable Drag Shocks (C2600). All said and done in a 1970 Nova with a 383 small block 29x15x9 Hossier tire at 10lbs I have consistant 1.55 60ft times good luck.
Theo is offline   Reply With Quote
Old 04-02-2010, 09:22 AM   #7
mr.mouse_trick
Get rid of the leafs and ladderbar it
mr.mouse_trick is offline   Reply With Quote
Old 04-23-2010, 08:56 PM   #8
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Suspension Question
I picked up a 68' Nova a few years back and it has an old school ladder bar/leaf spring setup with floaters to prevent binding. Don't know who built it, but it works great planting the rears and pulling the fronts about 6-8 inches off the ground.
I'm running a flat top 355/Glide combo with 4:88s and a 10.5x29.5 Phoenix tire and my 60ft. times are between 1.47-1.50 with a transbrake.
I know a lot of stockers run the Slide-A-Link bars, but I don't know if they work well with the mono springs. I've seen them work better with the multis. Even Cal-Tracs own split monos are thicker and stronger than the factory stuff that will still wrap up with any traction device that "hits" behind the spring eye.
Good luck with your ride...................Danny Durham
