Old 03-10-2010, 08:42 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default cooling system anti-corrosion products
Racers,
Since we are not supposed to run anti-freeze, let’s talk about cooling system anti-corrosion products.
For the last 10 years or so I have used distilled water and assorted “anti-corrosion, cooling enhancing” type products.
Let me hear what some of you are using.
Thanks
www.woodfinautomotive.com
Larry Woodfin 471W
Old 03-10-2010, 09:05 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: cooling system anti-corrosion products
Jegs sells a zinc that screws in the radiator where the drain **** goes. I have had one in my car since 95 along with the cooling additives and have not seemed to have a problem with corrosion. (alum heads with steel block)
EDIT
Was just out in the shop and looked while I was there the part number is 400-32060 and its made by flex a lite.
I guess the stars in the post are because the board thinks thats a bad word sorry if I offended anybody I can asure you I did not mean to do so.
Last edited by Rob Petrie E395; 03-10-2010 at 10:08 PM. Reason: added part number, sorry for the bad word
Old 03-12-2010, 10:05 PM   #3
njk53
Prestone makes a combination anti-corrosive and water pump lubricant. However, I also like the zinc bar that the corrosion in the system will attack instead of the engine/cooling system internals. The best thing is to never let corrosion start to begin with because there is noting on the market that will thoroughly clean a cooling system once corrosion has started.
Nelson Kowal
Stock 345
