Old 02-11-2010, 08:25 PM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Dana 60 question
While looking at rear disc brake kits they list two different ones for Dana 60. One says with green bearing other says w/snap ring style green bearing. Without taking it apart is there a way to tell the difference? Thanks
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-11-2010, 09:05 PM   #2
John Leichtamer Jr
John Leichtamer Jr's Avatar
Default Re: Dana 60 question
Ed
When you look at the outside of the bearing, the green brg. will have a fixed retaining ring made onto the brg. The original brg will have an ajusting type retaining plate. Can't remember witch side . If the rearend was cut down it could have any type on it.
Hammer
John Leichtamer Jr is offline   Reply With Quote
Old 02-11-2010, 09:36 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Dana 60 question
I don't think any "green" bearings have an adjuster like OEM. If I remember correctly, one version has a snap/retaining ring installed that the loose retaining flange sandwiches between itself and the housing end. The other version has a flange that is pressed onto the bearing. The snap ring, which is actually flat, is the prefered version. (Just remember to put the flange on the axle before pressing on the bearing.)
Old 02-11-2010, 09:42 PM   #4
Myron Piatek
Here is a close-up of the retaining ring version with loose retaing flange;
http://image.moparmusclemagazine.com...e_bearings.jpg
Old 02-11-2010, 09:55 PM   #5
John Leichtamer Jr
ED
Look in the Summit & Jegs catalogs they show the green brg in there.
Green bearings have a fixed retainer. They don't have adj.
Hammer
