Old 02-07-2010, 06:23 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question 77 Camaro Engine Mount Removal
During my winter refresh of my engine I wanted to also update the motor mounts from the original stock rubber pieces to a true solid mounting system. I went to take the rubber mounts off the frame today and found out that the there are not really any good ways to access the nuts that are inside the subframe. On the passenger side the 2 upper bolts had access holes in the sides of the subframe that I was able to use to get those 2 out, however the bottom bolt on the passenger side and all 3 on the drivers side do not have access. I can see the nuts through the bottom of the subframe where the lower control arms attach but I really do not want to pull the control arms off if at all possible to remove the old mounts and install the new solid versions.
Anyone out there have any "tricks" to gaining access to these nuts?
Thanks in advance,
Chad
Chad E532 is offline   Reply With Quote
Old 02-08-2010, 02:54 PM   #2
Logus
Default Re: 77 Camaro Engine Mount Removal
Ask/search here
http://www.nastyz28.com/forum/index.php
2nd gen Camaro site, it comes up here now and then
Logus is offline   Reply With Quote
Old 02-08-2010, 08:41 PM   #3
Rob3105
Rob3105's Avatar
Chad, you have a PM
Rob3105 is offline   Reply With Quote
