Old 02-04-2010, 08:42 PM   #1
marvstrick
Liked 33 Times in 10 Posts
Cool fuel line
i have a 502- 450 hp chevy. iam running#8 fuel line from regulator,my question is would #6 be better. c/cm 9777 marvin
marvstrick is offline   Reply With Quote
Old 02-04-2010, 08:48 PM   #2
njk53
Default Re: fuel line
Do you mean from the regulator to the carburetor?
Nelson Kowal
Stock 345
Old 02-04-2010, 08:52 PM   #3
marvstrick
Cool Re: fuel line
yes from regulator.
Old 02-05-2010, 08:46 AM   #4
Mark Lewis
Liked 207 Times in 44 Posts
Had a 750 from davinci that always ran better than a 850
Mark Lewis is offline   Reply With Quote
Old 02-05-2010, 09:11 AM   #5
tj310
If your reg is in front of carb bigger is better. Thanx Trevor
Old 02-05-2010, 08:53 PM   #6
Greg Reimer 7376
Liked 698 Times in 216 Posts
Cool Re: fuel line
This sounds crazy, but running a big huge line from the pump at the rear of the car to the regulator at the front can aggravate a fuel starvation problem.You can sit there with the pump on adjusting the regulated fuel pressure all you want, and to no avail, because the weight of the fuel in the large line reacts to inertia forces within itself, resisting forward motion inside the line ahead of the pump. A smaller main fuel line doesn't do this,because inertia forces on the fuel are much less. Sometimes,more isn't better. Number 6 AN fuel line is about 3/8" inch ID, the #8 should do it, but that's where the placement of the regulator in front of or to the rear of the carb might come into play here, as well.Pro stock cars leave so hard that it takes a huge push to overcome the weight of the fuel trying to stand still in the line.High pressure overcomes the inertia on acceleration, but floods the engine by overcoming the needles and seats when the car isn't accelerating.Critical balance here between fuel flow requirements of the engine,fuel line diameter,pump volumne,and pump pressure.
Old 02-06-2010, 01:48 AM   #7
Ken Haase
Aren't the fuel cells up front on Pro Stocks now?
Ken Haase is offline   Reply With Quote
Old 02-06-2010, 11:24 AM   #8
Greg Reimer 7376
Cool Re: fuel line
If they are, that's why!!
