Old 02-02-2010, 03:44 PM   #1
Greg Barsamian
Liked 427 Times in 97 Posts
Default Aluminum Rear Drum Info
In what year, make & models, ( S-10's) and / or vehicles did GM install Aluminum Rear Brake Drums?
Thanks
Greg
Old 02-02-2010, 04:19 PM   #2
W J
Default Re: Aluminum Rear Drum Info
Greg, I'm almost certain that many of the Buick GN cars circa 1987 used aluminum rear drums....maybe someone here will respond to this....WJ
Old 02-02-2010, 05:02 PM   #3
sterling simmons jr
Liked 138 Times in 28 Posts
Greg do you need some cheap.
804-387-6087
Sterling Simmons jr 1131 STK
sterling simmons jr is offline   Reply With Quote
Old 02-02-2010, 05:09 PM   #4
Jim Kaekel
Liked 535 Times in 110 Posts
This is just my .02, but I don't think the risk is worth the reward. I had a pair on my car several years ago and both developed cracks in the inner iron sleeve after just a couple of races. The friend that that got them for me worked at a muffler shop and said he had seen many of them cracked on street-driven cars, and told me to keep a close eye on them and that they were noted for cracking. I took them off and tossed them in the trash after finding cracks. I know of a couple of stockers that have run into the sand trap because of shattered aluminum brake drums.
Jim Kaekel 3836 STK
Old 02-02-2010, 06:14 PM   #5
427_ED
427_ED's Avatar
Liked 2 Times in 1 Post
I've seen them on '79-81 Malibus. The combination of ferrous and non-ferrous metals causes electrolysis problems. Don't use them.
427_ED is offline   Reply With Quote
Old 02-02-2010, 06:41 PM   #6
Doug Blackley
Doug Blackley's Avatar
Sometimes find them on 3rd gen Camaros and Firebirds.
Doug Blackley 1697 STK
Old 02-02-2010, 07:22 PM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
hmmmm, never heard of 'em cracking but i don't do a lot of brake jobs....
i DO have a pair laying around, though, if somebody needs 'em...
hell, i'll even resurface 'em..
Old 02-02-2010, 07:48 PM   #8
Robert Swartz
Robert Swartz's Avatar
Interesting, I'd considered this simply from a mass/weight viewpoint. What I'm thinking now, this might just be a "trick" idea that simply yields more potential headaches. Last thing I want is 3400 lb car running in 120mph range that doesn't want to stop? I'll file this in the bad ideas column.
Thanks guys.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 02-02-2010, 09:04 PM   #9
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Besides the electolysis one has to wonder about the different thermal properties as well. Seems like that would lead to cracking before anything else
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 02-02-2010, 09:48 PM   #10
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Aluminum Rear Drum Info
Greg- sent u a PM-Comp 387
