Old 01-28-2010, 01:18 AM   #1
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Converter question
I changed converters on my TH400 and now have .280 thou. clearance between it and the flexplate. I have never had to use shims before, last converter had .125 thou. I know the standard is 1/8 to 3/16 of an inch, but is the low or high measurment better? Are good quality washers a good choice for shims? Thanks.
Dana Fitzpatrick is offline   Reply With Quote
Old 01-28-2010, 02:11 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Converter question
I don't know if it's the "right" thing to do but we ran washers in Dad's bracket Camaro for about 8 seasons with no trouble.
Old 01-28-2010, 02:15 AM   #3
Liked 5,077 Times in 1,935 Posts
Default Re: Converter question
Yeah, you can use washers alright. Just match them within a couple thou. Make sure you still have some pilot in the crank. Most aftermarket stuff doesn't have as much pilot as the OEM did. You want to use as much of the pump drive as you can on the hub end.
Old 01-28-2010, 08:07 AM   #4
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Originally Posted by mark yacavone View Post
yeah, you can use washers alright. Just match them within a couple thou. Make sure you still have some pilot in the crank. Most aftermarket stuff doesn't have as much pilot as the oem did. You want to use as much of the pump drive as you can on the hub end.
x2
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 01-28-2010, 09:38 AM   #5
Bill Harris
Liked 26 Times in 13 Posts
Hey Lenny, did you get resettled in NC yet? Miss all that snow?
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 01-28-2010, 02:40 PM   #6
Sponsor
Hi Bill, yea we are up and running. I hate to say it, but it's 65 out right now. It will be in the high 30's this weekend with a sleet warning. Oh well, it's better than the long, cold Ct. winter's. How is your project coming along?
PS - No, I don't miss the snow at all!
Lenny Croteau
Phone 704-892-6837
