Old 01-25-2010, 09:01 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default converter stall speed?
I have a 67 camaro that weights 3160 the motor is a 400 sm block, cam at .50 is int 254 and ext 262, fast burn heads, 211 trans, 456 gears and tires are 29.50/ 9/15, I was wanting to know what stall speed would I need? Thanks
TinSoldier 3215 is offline   Reply With Quote
Old 01-25-2010, 11:45 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: converter stall speed?
Is it just a race car?,, or is it occasionly driven on the street? It makes a big difference.
Danny Durham
Old 01-26-2010, 12:04 AM   #3
283SS
Default Re: converter stall speed?
sound like u got a small cam in it so what trans r u running???? and r u foot braking it or trans braking it ???
283SS is offline   Reply With Quote
Old 01-26-2010, 07:16 AM   #4
Jim Bailey
Liked 584 Times in 94 Posts
Thumbs up Re: converter stall speed?
You have a pm.
Jim Bailey is offline   Reply With Quote
Old 01-26-2010, 03:38 PM   #5
ericsz
Call Art at Coan, he will fix you up!
Eric Bowling
ericsz is offline   Reply With Quote
Old 01-26-2010, 04:16 PM   #6
TinSoldier 3215
no playback tech!!! and yes it is a fulltime racecar!!!!!
Old 01-26-2010, 09:56 PM   #7
Geerhead55
Like what Eric basically said,,,any manufacturer can set you straight after you give them all your specs. Ballpark,, I'd think with a 400 and a not too crazy cam,, I'd guess you'd be happier with something around a 4000-4500 stall 8 or 9 in converter, compared to something like a 5500 or higher like us guys with smaller motors ( 327s - 350s) use.
Pick up your phone,,,you'll be glad you did. Good luck with your project.
Danny Durham
