Old 01-15-2010, 12:47 PM   #1
wagonboy
Liked 26 Times in 5 Posts
Default weight.....help
I have a 1980 malibu wagon. classification with a 305 makes it a natural M car. (14.33)- it has been run as a "N" car. The nhra tech sticker on the car says wt 3405 cid 305 hp 180/230. I have tried to figure that weight - is that accurate ?
wagonboy is offline   Reply With Quote
Old 01-15-2010, 02:38 PM   #2
Jeremy K
Default Re: weight.....help
N - 14.50 to 14.99
14.50 * 230 + 170 = 3505 lbs.
Looks like a mistake on the sticker, it's 100 lbs light.
Jeremy K is offline   Reply With Quote
Old 01-15-2010, 02:54 PM   #3
wagonboy
thats what I thought. I like the mistake number better!! I knew I could do math ! With the new rules, can a natural M car weight down to O ?
Old 01-15-2010, 03:03 PM   #4
Jeremy K
You can run 1 class up or 1 class down from it's natural class (M).
L- 3275 lbs
M- 3390 lbs
N- 3505 lbs
Old 01-15-2010, 05:06 PM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: weight.....help
Jeremy K . Is exactly right, up or down one class from natural class only !!
Good luck with your project...............
Dave Ribeiro 1033 STK
Old 01-15-2010, 07:52 PM   #6
Tom Moock
Liked 10 Times in 6 Posts
wagonboy, you can change the header panel to make your wagon a1983, then you can run M, N, O. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 01-15-2010, 09:31 PM   #7
wagonboy
Smile Re: weight.....help
Tom,
I was looking into that. Too bad NHRA factors that year 305 at 230hp too. I need to get my trans and converter sorted out- get the correct amount of weight in the car and see what happens. Thanks for the info.
Ryan
Old 01-15-2010, 09:46 PM   #8
7423
Originally Posted by wagonboy View Post
Tom,
Ryan
Another bracket racer going to the dark side!! LOL!! Read between the lines Ryan and have fun...............
Say hey to Pop for me
7423 is offline   Reply With Quote
Old 01-15-2010, 10:00 PM   #9
wagonboy
Charlie,
The "dark side" is more difficult than Darth Vader said it would be. That 83 header looks good- move to- O- you and me in a .10 under heads up battle,( providing there is a tail wind) whew, I'm sure they will fill up the stands to see that one.
Ryan
Old 01-15-2010, 10:26 PM   #10
Pat Cook
Ryan, what happen to the Falcon wagon?
Going stock eliminator racing eh?
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
