Old 01-12-2010, 09:40 PM   #1
stock eliminator
Default Light weight parts vs heavy parts
I was wondering what e.t. difference there is between light vs. heavy parts. For example stock pistons are heavy but CP or other brands are extremely light. Has anyone ran heavy then put in light ones and seen e.t. differance??
stock eliminator is offline   Reply With Quote
Old 01-12-2010, 09:55 PM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Light weight parts vs heavy parts
You may not get much for answers to that, publicly, maybe some in a PM though....
2894 STK
Old 01-12-2010, 10:26 PM   #3
stock eliminator
I figured it would be a touchy subject
Old 01-12-2010, 10:30 PM   #4
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Light weight parts vs heavy parts
Check out [email]cheating101@$creweveryoneel$e.com
Former NHRA #1945
Former IHRA #1945
T/SA
Old 01-13-2010, 12:25 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
Hey Ed,
that link doesn't work for me... :~)
must be a few too may $$$'S in it.. ;~)
Adger Smith (Former SS)
Old 01-13-2010, 05:55 AM   #6
james schaechter
Liked 1,436 Times in 299 Posts
Thumbs up Re: Light weight parts vs heavy parts
This isn't actually controversial.
There are specs on piston types and rods for weights,etc. In general, If it moves, lighter is better. I don't know if anyone could actually tell you how much better it was, but the piston example is a good one. The replacement stuff has a lot of benefits besides weight too. Better quality all of the way around. I would say that if you are building a stocker engine or any quality race engine, the core components need to be the highest quality and the lightest you can legally run and afford.
Even in drivetrain, every real serious effort points to lighter stuff. Alum shocks, lighter axles, lighter spools and gear, transmission parts, lighter clutches, etc. I am sure that there is someone out there that can point to an example to the contrary, but if you walk around the pits and look at cars, talk to racers, you will see what I mean.
James Schaechter 3163 STK
Old 01-13-2010, 02:00 PM   #7
mannymen
Liked 13 Times in 7 Posts
From light to heavy also works. It's all trial and error on the dyno
N/A
mannymen is offline   Reply With Quote
Old 01-13-2010, 03:36 PM   #8
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Very true, especially on smaller (gp bikes) added weight in certain areas keeps rotating mass inertia up, and will stabilize across accel ranges, sometimes, sometimes its better to be heavier.
In my experience on a dyno with very small very fast engines it best to reduce any "long" mass, pistons, rods etc. If you keep the roating mass closest to its cenerline the best obviously
Chris "drooze" Wertman is offline   Reply With Quote
Old 01-15-2010, 11:18 AM   #9
Greg Reimer 7376
Liked 717 Times in 220 Posts
Cool Re: Light weight parts vs heavy parts
One of the main advantages to light pistons,pins,etc. are found in the area of parts reliability.A heavy piston is harder to accelerate from either TDC or BDC. The rod likes to stretch more with a heavy piston and pin,(actually the rod DOESN'T like to stretch,but has to anyway).At the conclusion of the exhaust stroke, ther is no plug of compressed gas pro-viding resistance to the piston's headlong plunge up the cylinder toward the open valves in the head. The two rod bolts have the unenviable job of stopping the rod,piston,pin and rings from continuing out the top of the cylinder bore.When rod failure occurs, it usually happens on the exhaust stroke,hence two bent valves you usually find in the aftermath.NHRA has a minimum weight spec for the combined piston,pin,locks,rings and rod, and I found it to be rather generous. The minimum for a 327 is around 1200 grams, an OEM cast piston,stock pin, rings and rod (no bearing) is around 1402 grams. The legal weight allowance would also allow you to rebalance the crank by removing a lot of weight from the counterweights, making for a much lighter rotating mass.Any combination that would benefit more by a light flywheel as in a stick class, would like a light assembly as well.As to the drive train, in my earlier days with my Chevelle, I set the rear end up with a Moroso Brute Strength posi and OEM axles. No parts failures, but later I got a spool,billet axles, and a C clip eliminator kit. That whole assembly was several pounds lighter. I translated that into less inertia loads on everything else, and the car was consistantly .08-.10 quicker in 60 foot and subsequent ET's.Talk to Dave Smith at Pro Trans for an opinion of what aluminum drums and light trans parts will do for your combination. I'd rather put the weight back in the weight box rather than everyplace else. A further note, I used to race a 409 Chevy, and the stock forged piston,made by TRW, weighed 1040 grams with no pin, no rings or locks. That thing was like a forged aluminum flower pot!!!
