Liked 54 Times in 7 Posts
Does anyone make a valve spring shim thicker than 0.060"?
I am looking for something in the 0.100" range so i do not have to stack up 2 of the 0.060 thick shims. My thought is that the fewer amount of shims I use the better I can keep things running straight and true to the valve rather than stacking up a bunch of shims that could make the spring sit out of square. Thanks, Chad |
Have you thought about using -0.050" locks and only one 0.060" shim? Just a thought...
Liked 552 Times in 215 Posts
Use a spring cup or id type spring seat plus the shim.....
Liked 69 Times in 32 Posts
call matt steen at victory engines 507-532-2436 he can custom make anything you need
i have had them made up to .250 thick with a center locating ring works great, |
That is what I use. If that and a locating spring seat still won't get it I add shims. The -.050" locks get you more clearance from the rockers too.
Ed Wright 4156 SS/JA |
Liked 10 Times in 7 Posts
What dia. springs are you using.
I am running 1.500" OD dual springs. The heads were setup for 1.950 installed height with the hardened locators and 0.030" of shim already under the locators. They are AFR 195 Eliminator heads that run 8mm 10 deg retainers and keepers so I am not sure if anyone makes the -0.050" drop retainers. I looked at AFR and they only list the "standard" height versions. I originally bought the heads assembled with their springs, but on this winters refurb I was planning on installing the correct springs from the cam card which run the different height.
Thanks Chad |
#8 | |
Use a spring cup. Buy or have one made if necessary. It will help control the spring, especially if you have multiple shims under the spring right now. I picked up some good RPM when I made the change on my stocker.
Jeff Lee 7494 D/S '70 AMX |
