Old 12-30-2009, 09:54 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default what size cam?
I have a racecar that weights 3150 with a 400 small block, fast burn heads, v.jr intake. what size cam do I need to go 6.40's in the 1/8. H.roller cam please.
TinSoldier 3215 is offline   Reply With Quote
Old 12-30-2009, 10:16 PM   #2
partsbob67
Liked 79 Times in 11 Posts
Default Re: what size cam?
try giving the guys at bullet cams a call.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 12-31-2009, 05:48 PM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: what size cam?
takes more then a cam to run 6.40's.....what converter & trans do you have? Dose it have a trans brake? is it tubed ....what gear & tire size? What size carb do you have ?
Old 01-01-2010, 01:31 AM   #4
Aaron Keown
Aaron Keown's Avatar
Regardless of all the parts that everyone else is asking you about,with the parts that you have already listed you may as well forget about any kind of hyd. roller because that just is'nt going to cut it unless you have some unforseen power adder that you are not telling us about.Its time for you to start thinking solid roller my friend,cause thats probably gonna be the easiest and cheapest way for you to accomplish your goal.Give Gordon Holloway at Comp Cams a call and he will help you to decide what is right for you.
Aaron Keown is offline   Reply With Quote
Old 01-01-2010, 06:08 PM   #5
greg fulk
greg fulk's Avatar
