Old 12-30-2009, 02:08 PM   #1
sprnova
sprnova's Avatar
Default ahfs question
In this statement it says any run of 1.25 is automatic even at altitude tracks.
Runs of 1.250 or more under the index will be reviewed and adjusted Tuesday following the event. Runs at National Events, Divisional Events, and National Open Events, including those at altitude factored race tracks, are included in the 1.250-second-or-more-under analysis. This is done to better react to any out-of-line indexes or under-horsepowered combinations. Therefore, at all such events, a 3.25 percent horsepower adjustment or index reduction will be initiated Tuesday following the event. The decision to adjust horsepower or to reduce the index will be at the discretion of the NHRA Tech Department
Does this mean 1.25 under the altitude index or 1.25 under the sea level index?
sprnova is offline   Reply With Quote
Old 12-30-2009, 03:08 PM   #2
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Red face Re: ahfs question
I have a sneaking suspicion they mean the altitude factored index. Guess we will not know until they clarify the rule or the first race it happens. Jim
Old 12-30-2009, 04:34 PM   #3
art leong
Default Re: ahfs question
I hope you are right Jim. But I woulkd still like to go to a density altitude format. To really make it equal.
Art Leong 2095 SS
Old 12-30-2009, 05:05 PM   #4
Ty Webb
It should count for AHFS at alt. tracks based on alt. index. The factor is good enough for records, it should be good enough for HP. Competition Eliminator can get their indexes hit at altitude tracks based on alt. indexes, S/SS should also.
Ty Webb is offline   Reply With Quote
Old 12-30-2009, 08:03 PM   #5
RPinoski1
Wink Re: ahfs question
I agree 100%.
Besides everyone knows that a big block isn't affected nearly as much as the small block at altitude. Right?
RPinoski1 is offline   Reply With Quote
Old 12-30-2009, 09:48 PM   #6
Shawn S.Kvaas
Ty the comp cars don't get hit during qualifying.
Shawn S.Kvaas is offline   Reply With Quote
Old 01-01-2010, 11:46 AM   #7
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
It's sad that so many people know so little about the rules they race under.
Bob Mulry 7516 STK
A & M Motorsports
Old 01-01-2010, 06:17 PM   #8
JRyan
Liked 112 Times in 31 Posts
Ty,
Do you know that if you run 1.25 under the altitude factored index for the record, that you don't get the record at 1.25 under? It's LESS than that, and it varies dependant on which altitude track you set it at and the correction factors applied when it's factored back to sea level. So then it really isn't a 1.25 under run, and shouldn't be the cause of a HP factor. But we have no clarification on that either!!
The fact that NHRA personel previously had to do a bunch of paperwork to figure this out at altitude tracks is the reason they just let altitude factored runs go until now.
Jerry
Old 01-02-2010, 09:47 PM   #9
Pvt Parts
Pvt Parts's Avatar
Wait a minute. It seems that everyone is getting caught up in the emotional part of this discussion and speculation. The answer is right there in front of you. Strip away all of the B.S. and political nonsense and read the words.
End of story. Everything else is secondary and irrelevant. Plead your case but in the end it's their decision.
Old 01-02-2010, 10:51 PM   #10
Liked 5,109 Times in 1,947 Posts
That sentence alludes to an either/ or situation, not some arbitrary decision.
No wonder you're still a Private. Get back in line, soldier
