Old 12-21-2009, 05:12 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default TH350 Cooling Line Fittings
Does anyone out there know of a source of a fitting that will thread into a stock TH350 transmission case and get me to a -6AN male fitting? The case has an odd thread that I believe is a 1/2" BSPP thread. From the factory there were brass adapters in the ports to connect to the steel tubing with an inverted flare fitting which I am currently using to get me to -6AN hose but it takes too many connections (possible leak points) so I want to clean up the plumbing and install some quick disconnect fittings on the trans lines, but all the kits that are available that I have seen either have 1/4" or 1/8" npt threads which will not work in this application.
Thanks
Chad
Chad E532 is offline   Reply With Quote
Old 12-21-2009, 05:34 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 852 Times in 234 Posts
Default Re: TH350 Cooling Line Fittings
ATI has the proper fittings you need . #6an x straight thread ,with a gasket seal .....You can find them from Parker hydraulics in steel,if you have a counterman willing to take the time to look it up for you. .....Tom
Old 12-22-2009, 05:11 PM   #3
Jim Kaekel
Liked 529 Times in 107 Posts
Tom is correct, the ATI fittings are the best way to go. Most people use 1/4" NPT pipe to -6AN adapters, but be very careful tightening them.
Jim Kaekel 3836 STK
Old 12-23-2009, 09:20 AM   #4
njk53
Is the thread for the trans. line on a stock 350 case a 1/4 NPT?
Nelson Kowal
Stock 345
Old 12-23-2009, 12:36 PM   #5
Jim Kaekel
Yes, the TH-350 is 1/4" NPT, as is the TH-400. I think all NPT to AN adapters made by Aeroquip, Earls, etc. are tapered NPT, rather than the OEM which is not tapered and uses a sealing washer. You can definitely crack the case if one of these type of adapters is over tightened due to the fact it is tapered.
Jim Kaekel 3836 STK
Old 12-23-2009, 01:42 PM   #6
Chad E532
Chad E532's Avatar
I talked with ATI tech and they have 1/4"-18 fittings that have the straight thread that is in my case. The pitch is 18 just like 1/4" NPT but it is straight. I found that there is a NPS (National Pipe Straight) thread that is used on low pressure hydraulics.
Thanks,
Chad
