Old 12-16-2009, 09:49 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default trans low gear, stall speed input.need help
motor is 400 sm block running compression 12/5/1,trans haves a 211 low gear,8inch converter with a 5,000 stall,rear gear is 488 on a 29/9/15,weight of car is 3150,and shifting at 6500 and going thought the traps at 6800,cam is Q.50 int/236 and exh/242 best et is 10.51 at 125.12 off trans brake. need help or input on stall speed was told that I need a 4,000 stall would really not like to waste money on wrong stall speed. we are changing cams over the winter and going with a Q.50 int/249 and exh/262. thanks for help!!!
TinSoldier 3215 is offline   Reply With Quote
