Old 04-11-2007, 08:21 PM   #1
will prater
Liked 7 Times in 4 Posts
Default Dragster vs door car advantages
Looking for some comments from drivers of both dragsters and door cars of the advantages or disadvantages of either running together in a no electronics, no tranny brake, no air/ electric shifter class.
Thanks
Will Prater
wprater
will prater is offline   Reply With Quote
Old 04-11-2007, 09:19 PM   #2
Bryan Gillespie
Banned
Default
W. T. F.
Bryan
s/g & s/p 120
s/st & s/c 1219
Bryan Gillespie is offline   Reply With Quote
Old 04-11-2007, 10:07 PM   #3
Bracing
Default
Most classes that dont allow electronics wont alow dragsteres either you should clarify your post a little more im confused
Bracing is offline   Reply With Quote
Old 04-12-2007, 07:29 AM   #4
will prater
Default
The track where we bracket race has two classes. Super pro and non electronics class. No one has run a dragster in the no electronics- foot brake only class before this year. But the rules allow it and it may be happening more.
So what I am asking is; what are the advantages if any to run a high hp -low weight pipe rack against the full body cars. What I hear the most is the advantage at the finish line judging the stripe.
wprater
Old 04-12-2007, 08:36 AM   #5
SST1699
Default
Will,
The advantage is always to have the quicker car and be "the chaser" instead of the one being chased. So if you've got a fast door car, it's the same as a fast dragster.
One concern would be your "high horsepower" dragster running too quick for the class. Now you've got to slow it down somehow without killing your reaction & 60 ft times. Drgasters are definitely easier to maintain and repair between rounds, but they all look the same...
Good luck
Eric Saydlowski
2003 NESSA Champion
1973 Dodge Dart Sport
superst169@aol.com
Eric Saydlowski
Pittsfield, MA
SuperSt169@aol.com
S/ST 1699
2003 NESSA Champion
SST1699 is offline   Reply With Quote
Old 04-12-2007, 12:39 PM   #6
DB
Default
for you i would say dragster,point it hold on and hope!
DB is offline   Reply With Quote
Old 04-12-2007, 06:39 PM   #7
Carl Juliano
Carl Juliano's Avatar
Liked 64 Times in 25 Posts
Default
The obvious advantage a dragster has is much better vision.
Carl Juliano
TS 1275
Juliano Racing
Carl Juliano TS 1275
John Juliano SG 151
Carl Sr.
Carl Juliano is offline   Reply With Quote
Old 04-12-2007, 10:36 PM   #8
102digger
Default
the dragster gives you a better advantage at finish line.very easy to see.
racing stuff for sale
102digger is offline   Reply With Quote
Old 04-12-2007, 11:08 PM   #9
Bracing
Default
I've never heard of a non electronics class letting dragsters in I wish that was the case around me I have a new american race cars dragster coming i'd put a punk small block in that thing and foot break it till the wheels fell off
Old 04-13-2007, 09:17 AM   #10
GaryGoFast
Default
Bottom line is once you leave the starting line its just like any other race but I think you will have some issues hitting the bottom bulb green with a dragster as it will make it dificult to find your spot on tree.
gary
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
