Old 12-07-2009, 10:27 PM   #1
stock eliminator
Default 12 bolt need help with I.D.
the tube is stamped KDC 251.. What's it out of?????
I have pic also
stock eliminator is offline   Reply With Quote
Old 12-07-2009, 10:33 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 12 bolt need help with I.D.
since it is out of a Chevelle that narrows the choices. Those were used from 1964 - 1972
The 1964 - 1967 were more narrow than the 1968 - 1972. So if someone knows the width of either the early or later, we will have the answer.
Larry Woodfin 471W
Old 12-07-2009, 10:34 PM   #3
stock eliminator
how do you know its out of chevelle?
Old 12-07-2009, 10:54 PM   #4
It is either out of a Chevelle/Monte Carlo of some vintage, or out of a big car (Impala, Caprice, wagon) because it is set up for a four link and coil springs.
Old 12-07-2009, 11:32 PM   #5
FED 387
Liked 333 Times in 180 Posts
Thumbs up Re: 12 bolt need help with I.D.
Housing widths --------backing plate to backing plate
64-67 Chevelle ---61 inches
68-72 Chevelle/Monte Carlo----62 inches
65-70 Big Car----62.4 inches
Comp 387
Old 12-07-2009, 11:49 PM   #6
FED 387
upon further review it is probably out of a early model year 1972 el camino/monte carlo/chevelle
KD ---is the gear ratio 2:73
C------is the assembly plant--- Buffalo
251---is the assembly day of the year---September 8, 1971
Comp 387
Old 12-07-2009, 11:51 PM   #7
FED 387
forgot to add check the differential casting-- for a 12 bolt it should be 3969278
Comp 387
Old 12-07-2009, 11:55 PM   #8
Dragsinger
"how do you know its out of chevelle?'
I have a good eye for rear ends! [smile]
Larry Woodfin 471W
Old 12-08-2009, 12:00 AM   #9
The big car 12 bolt doesn't have the ears on the center casting.
Old 12-08-2009, 01:11 AM   #10
Mark, the one we have does. Well, it did, they were cut off. The Chevelle housing does not have the big inner pinion bearing, or the big carrier bearing saddles. This housing has the big inner pinion bearing and the ears cut off of the top of the center casting, or at least almost all of them are gone. I've seen stock Chevelle and Camaro housings cut for the big carrier bearings, but I've never seen one cut for the big inner pinion bearing. It might have been there on some COPO Chevelles, but those cars were very rare, and I doubt anyone cut one of the housings up like that to fit a Camaro.
