Old 11-03-2009, 11:14 PM   #1
taylor51
Default 94 camaro pk race cars ss/gt or ss rolling chassis
for sale here is a 94 camaro super stock gt rolling chassis, this car was built new in 2004 by PK Race Cars in Ohio, car has had 2 owners before myself, has less then 250 total runs since chassis was brand new. I bought the car in june of this year and have totally updated/refurbished it from front to rear, i have replaced or am in the process of replacing the following items, complete fuel system, front carpet, seats and seat covers, all gauges and tach, shifter, complete co2 unit, batteries, all wiring, all battery cables, ect., ect., ect. This car is one of the nicest if not THE nicest 4th gen camaro ss rollers in the country, you will not find a more detailed car anywhere in this price range!!!!
following features are included......
2004 pk chassis, chromemoly cage, 4 link with wishbone, and wheelie bars.
all suspension parts and rear end powdercoated "silver vain", cage painted gun metal silver metallic
strange 9inch 3.812 ultracase with 1350 yolk, 5.83 pro gear, and 40 spline gundrilled axles with new 5/8's studs
strange billet disc brakes front and rear with strange braced master cylinder and biondo line loc
strange double adj. front shocks, koni double adj. rear shocks. front end set up by richard doane with alf wiebe componets
dynatech alum. metal matrix driveshaft with 1350 u-joints and roller bearing trans yolk
weld 2.0 alumstar front and rear, 28 inch moroso fronts, 12.5x31.25x15 m/t rears. can fit much bigger tire. new crc front lightweight wheels nuts and spacers
weight box and weight rack, have 300# of weight bars and loose weight that comes with the car
brand new autometer record/playback tach, shift lite, oil pressure warning lite, oil pressure, fuel pressure, water temp, trans temp and volt gauges
k&r complete wiring system with fuse/relay board and switch panel, car is being completely professionally rewired and all new battery cables front to rear
2 brand new optima red top gel cell batteries
msd 7al-2 ign with new hvc II coil, 3 step and rpm switch
brand new hurst pistol grip quarter stick and biondo co2 bottle, gauges, mount, and shifter. set up for a powerglide
complete brand new fuel system front to rear with the following items, jaz 3 gallon clear pro cell, magnafuel prostar 500 pump/filter, magnafuel 4 port regulator, 12an from cell to filter, 10an pump to reg, all new an lines and fittings
brand new kirkey 17.5 wide alum. seats with new gray tweed covers. seat shells powdercoated "siilver vain". window net and all mounts powdercoated "silver vain"
new carpet, shifter mount, seat mounts, ect. custom pk interior/door panels, headliner, trunk area, ect. all gray tweed. all small items powdercoated "silver vain"
new biondo terminator button and custom mount
2 sets of custom step headers and collectors, both are stahl pattern
front motor and mid plate, both powdercoated "silver vain"
gm factory alum. radiator with 16 inch electric fan
paint and body are in good shape, body has small dent on drivers side rear 1/4 panel, trunk area, underside of car, and engine area all solid blue painted, same as body color. car was a low milage street car and is very nice.
i have many pics i can email also.
asking price is $30,000 rolling obo. you will not find a car this nice or this detailed anywhere for this price!!! i have a 700hp 421 sbc and coan reid cased glide available also, engine and trans are both 100% brand new with dyno time only on the engine, call for price if you are looking for a complete car.
more info or questions please call:
mike taylor
641-425-0391 cell
641-423-7165 home
641-424-6111 work
mgt16@mchsi.com
Trades ACCEPTED: only trades considered are extremely nice back halfed gm door cars, 3rd gen. camaro super stock cars, 24 inch or wider cage 2008 or newer swing arm/4 link dragsters, or newer style pro stock cars/trucks
taylor51 is offline   Reply With Quote
