Old 10-18-2009, 06:47 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default adjustable rear shocks
Please give me your opinion about single vs. double adjustable rear shocks. Specifically, for the 1990 Firebird I have under construction.
The car will weigh about 2900 with driver, performance will be high 9’s [¼]
It is small block powered, a 408 SBC of about 635 - 645 horse. This is an electronics racer with trans brake, delay box, ladder bars, custom sub frame, full cage, well braced chassis. The tires are M/T 29.5 x 10.5S on 10” wheels.
At this time I am considering the AFCO single adjustable with 5” travel. [this chassis uses coil overs mounted behind the rear axle]
Also, I will use a quality adjustable front strut. [it has OE front suspension]
This is a very nice, well done car. Let me hear your thoughts.
Thanks
Larry Woodfin 471W
Old 10-18-2009, 07:13 PM   #2
S/ST4707
Default Re: adjustable rear shocks
Larry, go double adjustable if you budget will allow. It provides for finer tuning of the rear suspension. I prefer Koni but AFCO is a good product.
S/ST4707 is offline   Reply With Quote
Old 10-19-2009, 11:23 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 858 Times in 234 Posts
Kenny, Your car will benefit greatly from a pair of double adjustable shocks. ......Small tire ,ladder bar cars can be tricky to keep hooked after the initial hit......D. A .shocks will help ......I also like the Koni's for my own car,but I have used AFCO's on several of my customers cars ,and have found them to be a very good shock........Tom
