Old 10-12-2009, 03:00 PM   #1
Stewart Way
Liked 70 Times in 22 Posts
Default NHRA rod and head cc info
Anyone know why NHRA has removed the latest Head cc numbers page and replacement rod page? The latest head cc page is now 1/21/09 and the latest rod page is 1/15/09/ I know there were newer pages but I can't find them now. Both those pages containing the Chally Drag Pak info are gone.
Old 10-13-2009, 09:49 AM   #2
bsa633
Banned
Default Re: NHRA rod and head cc info
It may have something to do with the new Mustangs being tossed at Indy..Who knows..
bsa633 is offline   Reply With Quote
Old 10-13-2009, 10:53 AM   #3
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Not sure if this is what you were looking for;
NHRA Technical Specifications
For
2009 Chrysler Corp. Motors
ROD
BORE STROKE DISPLACEMENT CYLINDERS LENGTH
3.920 3.580 345 8 6.200
4.000 3.580 360 8 6.123
4.055 3.580 370 8 6.200 3/20/2009
Issued: 3-20-09
Revised:
Specifications for 2009 Chrysler Corp engines.
H.P. Disp. C.R. Ind. Make Casting Intake Lifter RR Head Notes
Manifold cc’s
305 345 12.7 MPI CHRY P5155173 P5155184 H/R 1.60 71.7 A
275 360 11.4 MPI CHRY P4510046 P4510046AB H/R 1.60 56.0 B,C
385 370 12.6 MPI CHRY P5155173 P5155184 H/R 1.60 71.7 A
Throttle Bore Size
A/B – 1.75 inch
C – Aluminum roller tip rocker arm
H.P. Disp. Deck Cl. Piston Height Vol Valves Cam Lift Springs Gasket
305 345 .000 Dome .205 16.4cc 2100/1600 584/552 Beehive .026
OEM Diamond piston #46191
275 360 .004AB Flat w/ Notches .000 6.8cc 2020/1600 490/490 Outer w/Damper .040
OEM piston #51021
385 370 .0135BD Dome .137 14.8cc 2100/1600 584/552 Beehive .039
OEM Diamond piston #46192
Head Castings
305 345 05037369AA
375 360 P5153847
385 370 05037369AA
Eric Merryfield 1883 STK
Old 10-13-2009, 11:36 AM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
Stewart, what you are looking for is in a new location. Go to Competition on the first page of the NHRA site, from there click on NHRA Accepted Products, on that list is SS Head volumes, click on that and page to about page 56 or so. The new hemi is listed there as 191 intake and 60 exhaust. The 360 is not yet listed, but is being pored this week to get this figure. Hope that helps.
Jeff Teuton 4022 STK
Old 10-13-2009, 01:12 PM   #5
Stewart Way
Jeff
Thanks for steering me in the right direction. I was going to NHRA, then Competition on the bottom of the page, then to replacement rod section and SS runner volumes and the info wasn't there. Guess they don't update that section anymore. Maybe I am as slow a Warren tells me I am.
Thanks
