Liked 3 Times in 1 Post
I am going to install an oil accumulator on my BBC Stocker. I am afraid to lose another motor.
This is what I have already found out. I want a 3 quart accumulator. I want to use a solenoid at 35 to 40 psi. I have bought the adapter to run filtered oil to the accumulator. Does anyone have any other thoughts about oil accumulators? the factory suggests filling it with 30 psi and lowering it to below 10 pounds. Is this correct? How much more oil do you run? |
Liked 165 Times in 59 Posts
i have the accusump brand ,,i have had it for four years and is worth the insurance ,,i have the electric solenoid and my presure is a little lower at 25 psi,,the instructions say to presurize the container to 15 psi ,what i do is fill the crank case with five quarts and prime the engine,,this will build to about 60-70 psi on the presure gauge on the accummlator (i have mine hooked up to the ignition switch) turn on the ignition and let it fill back in to the pan ,,,not all the way this will bleed out the air pockets,,,add the remaining quarts (3 quarts if you have a 5 quart pan) for a total of 8,,the beauty of this is every time you hit the ignition it primes the engine,,no more dry starts,,and protected in the event of oil not being at the pick up it will supply the pump ,,,you want to mount this as close to the feed point to engine as possible this will help performance of the accusump system ,, keeping line length short
gmonde |
