Old 09-29-2009, 09:44 AM   #1
bighead
bighead's Avatar
Talking Tracy Dennis/Steve Williams 582 Pro Series Raffle Results
Greg Morris Memorial Golf Tournament Engine Raffle
John Brener from Abida Springs, Louisiana was the lucky recipient of the Tracy Dennis / Steve Williams Sunset Racecraft 582 Pro Series Engine giveaway. John was the last man standing as ten tickets were drawn and one by one were eliminated.
The nine other people that were eliminated will each receive a $250 K&N Engineering gift certificate courtesy of Steve Williams. They are Buddy Wood, Clyde Griffith Sr., Johnny Covington, Anthony Castillo, Tommy Turner, Richard Wilk, David Jones, Larry Smith, and Mike Ferraro.
Congrats to all winners and thanks to everyone that purchased an engine raffle ticket.
The Greg Morris Foundation would like to thank the following suppliers and manufacturers for there help in making this engine give away possible:
APD 1150 CFM Drag Race Carb W/Billet Metering Blocks and External Linkage
ARP Flex Plate Bolts, Head Studs, Valve Cover Stud Kit
ATI BBC Damper 7” One Piece Steel Hub, SFI Flexplate
Autolite Racing Spark Plugs
Brodix BB-3 XTRA CNC Oval Port Heads, 3 XTRA Oval Port Intake Gaskets,
BBC Head Hunter Intake Manifold
Callies BBC 4.375 Magnum Crankshaft
Clevite Main Bearings and Rod Bearings
Cometic Head Gaskets
Comp Cams 3XTRA Standard Roller Camshaft w/4,7 swap
Crower BBC Tall Lifters
CV Products BBC Sportsman Cam Drive
Dart BBC Big M Engine Block, BBC STD Coated Cam Bearings, Freeze Plug Kit
Diamond BBC 4.600 x.375 3Xtra Pistons
Earls -12 Flex hose
Federal Mogul BBC High Volume Oil Pump
Fel-Pro Fuel Pump Gasket, Pan Gasket, Rear Seal, Valve Cover Gaskets
Goodridge -12 90 Degree Max Flo Swivel
GM Mark IV BBC Front Gasket, Intake Bolts, Oil Filter Adapt, Dist. Clamp
Joe Gibbs Break In Oil
K & N Oil Filters
Manley BBC H-Beam 6.535 Rods, ARP2000 Rod Bolts, Pushrods
Moroso Dowell Pins, Oil Pump Drive Shaft, Oil Pump Pick-Up and Stud Kit, Oil
Pan and Bolts, Timing Pointer, Carb Stud Kit, 4 Vane Vacuum Pump,
Crank Pulley, Vacuum Belt, -12 AN Positive Seal
MSD Distributor, Crank Trigger, Flying Magnet
T & D Shaft Rocker with One Piece Stand
Total Seal Piston Rings
VP Racing Fuel
Williams Products BBC Billet Rail Valve Covers
Craig Anderson
bighead is offline   Reply With Quote
