Old 09-26-2009, 10:47 AM   #1
JMatt
JMatt's Avatar
Default SG Door car tire pressures
Just curious where people are finding their best tire pressures. I search, but most threads seem to come from dragsters running 5-6 pounds.
I'm in a 2600 pound door car. Currently 60' in 1.200 seconds. 1.80 glide, 4.30 rear end. 104" rollout rear tires (NOT stiff sidewall).
I run about 9.5 pounds hot. 8.5 cold. +/- based on weather.
Too high? Too low? Just right?
JMatt is offline   Reply With Quote
Old 09-26-2009, 03:06 PM   #2
JMatt
JMatt's Avatar
Default Re: SG Door car tire pressures
No Super Gas cars on this forum?
Old 09-26-2009, 04:58 PM   #3
GRIGGS
The more air pressure you can run the better. It will also help your rt. I run anywhere between 10 to 12 lbs. depending on track conditions, but I do run more than most. 3200 lb Chevy II. Hope this helps some.
GRIGGS is offline   Reply With Quote
Old 09-26-2009, 06:05 PM   #4
JMatt
JMatt's Avatar
Sure that helps. Thanks. Love to hear more people's examples too.
Old 09-27-2009, 05:30 AM   #5
Lou SG2340
7lbs on a 2250lb roadster with 33x16 Hoosiers. Same pressure hot or cold
Lou SG2340 is offline   Reply With Quote
Old 09-27-2009, 12:38 PM   #6
frank v
i run 8lbs in a 2550 door car hot or cold
s/g 1620
frank v is offline   Reply With Quote
Old 09-27-2009, 06:33 PM   #7
JMatt
JMatt's Avatar
Same pressure hot or cold? Don't your cold tires coming off the trailer heat up enough to add a pound from the first burnout?
I'm trying to get to about 9.5 pounds immediately after the burnout. That's why first pass I have set about a pound lower.
Am I doing it wrong?
Old 09-27-2009, 07:16 PM   #8
CH.CRAFT
Location: PORT ALLEN, LA. NEXT DOOR TO STATE CAPITOL RACEWAY
Originally Posted by indyracer View Post
same pressure hot or cold? Don't your cold tires coming off the trailer heat up enough to add a pound from the first burnout?
I'm trying to get to about 9.5 pounds immediately after the burnout. That's why first pass i have set about a pound lower.
Am i doing it wrong?
my 33.5x15 stiff wall goodyears increase approx. .75 to 1.0 lb. From cold to hot. I run 10.0 lbs. Hot, 3200 lb. Camaro.
CH.CRAFT is offline   Reply With Quote
Old 09-28-2009, 07:02 AM   #9
roseracing
roseracing's Avatar
We alway run 7.25lbs, hot or cold. 1971 Challenger, 2640lbs w/driver, 33x16 Hoosier tires, runs 155mph.
If you can run more air, still cut a light and not spin - then your better off with more. Our car happens to like it in between 7 & 7.5.
Brad
roseracing is offline   Reply With Quote
