Old 09-20-2009, 04:55 PM   #1
69camz28
Default Cal Tracs Springs
Hi guys. My name is Jeff, I am new to the forum. I was hoping someone could help me out a little with a few questions I have. I have a 69 Camaro - I am trying to set the suspension up like a Stock Eliminator Camaro ( I don't run in the class). I have a factory front suspension - A-arms are stock w/ polygraphite bushings, factory springs with 1 coil cut, no sway bar, and Cal Tracs shocks. In the rear I had Cal Tracs bars with multi-leafs and Rancho 9way shocks. With this set up I ran a best of 10.90 @ 121mph, best of 1.46 60ft off the footbrake and a 275/60/15 MT Drag Radial.
I recently purchased the Cal Tracs split leaf mono, and I had some quesions. The springs appear to have moved the tire forward slightly in my rear wheel wheel, maybe by a 1/4 inch or less. The car also sits slightly lower than it did....Have any of you had an issue like this? Also, what is the largest tire I can run w/o a minitub? Any front end suspension tricks you could share? Sorry for the long post, was just hoping someone could steer me in the right direction.
Thanks,
Jeff
69camz28 is offline   Reply With Quote
