Old 09-20-2009, 07:18 AM   #1
hotrod1446
hotrod1446's Avatar
Default Engine Diaper vs Exhaust Headers
Not sure if it has been mentioned on here before but it seems in most cases the diaper will touch a header tube on plenty of applications. Are these diapers burn proof?
www.EngineHones.com
hotrod1446 is offline   Reply With Quote
Old 09-20-2009, 08:03 AM   #2
ERNIE GRIGGS
Default Re: Engine Diaper vs Exhaust Headers
If you call dre he will install a heat shield on his diaper. It worked for me !
ERNIE GRIGGS is offline   Reply With Quote
Old 09-20-2009, 09:58 AM   #3
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Engine Diaper vs Exhaust Headers
DRE is the only sporsman diaper that has heat cloth available for header clearance,also motor mounts cut out.We have these in stock call with any questions 217-454-5289
DIAPERMAN is offline   Reply With Quote
Old 09-21-2009, 07:45 PM   #4
Ted Barnes
Ted Barnes's Avatar
I have one of these with the heat shield. It pretty much touches a couple of the primary tubes...with no problems ...
Ted
Ted Barnes 1511 HR
Ted Barnes is offline   Reply With Quote
