Old 09-04-2009, 08:24 AM   #1
FED 387
Liked 335 Times in 182 Posts
Question any body(Ford)& fender men here???
Have a 2000 Ford Super Duty extended cab with the factory installed rubber belt mouldings on the doors. One of them has started to come loose on the rear door. How can I reattach it??? Use glue, screws ,pop rivets or what??? Looks kinda hard to clamp it as there is not a lot of space between the edge of the door and the cab when the door is in the open position. Any suggestions would be helpful---thanx Comp 387
Old 09-04-2009, 09:04 AM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: any body(Ford)& fender men here???
Visit a auto paint supplier and ask them. 3M is what I have used. You may have to heat it with a hair drier to make it more pliable before you reattach it.
Sean
Sean Marconette
84 Mustang
5060 SS/N
