Old 09-02-2009, 06:00 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1968 L78 396 Block, Heads, Crank, Bellhousing
1968 396-375HP 4 bolt block casting number 3965440 dated E-21-8 with front pad stamped T0524MQ 18N449843. The block is standard with two sleeves in it and has been cleaned, magged and pressure tested good and will clean up at 30 over. I have the 3919840 square port heads dated C-11-8 and C-25-8 that are a stock bare set that have been cleaned and magged along with the steel 6223 standard crankshaft and the original 3899621 aluminum factory bellhousing all cleaned up as well for $2750. 330-770-2517
Last edited by dlv4540; 09-02-2009 at 06:02 AM. Reason: Forgot to put the dates in.
dlv4540 is offline   Reply With Quote
