Old 09-01-2009, 09:04 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Front Runner Tires - which brand?
Hello all,
I run my Camaro in PRO ET 1/8th mile. ET Finals are 1/4 mile in Topeka.
I am concerned that the tires may not hold up to 120 in the qtr. I run 7.12-7.20 in the 1/8 at 95 mph.
I am considering changing from my radial street tires (on 15x3.5" Welds) to drag racing front runnners.
Which brand would you recommend, and why?
Goodyear, Hoosier, Moroso.
I have heard that Hoosiers dont last very long.
I have heard Moroso tires last forever.
A friend recommended Goodyears.
My reaction times are decent, so I am not going to change to another diameter.
Thanks
Clark Doukas
Old 09-02-2009, 07:53 AM   #2
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Front Runner Tires - which brand?
I have always had good luck with Moroso front tires. Whatever you use make sure that the front end is aligned properly or you will wear out any tire you put on.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 09-02-2009, 12:57 PM   #3
Michael Pliska
On my S/G car I have a set of Moroso tires which I bought originally 21 years ago, they still work great and do not have any cracks in them. I switched over to a shorter set of M&H Racemaster front tires (which are about the same age, but more passes and much more wear), and it was noticeable that I had to "drive" the car more.
Michael Pliska 643 S/G
Michael Pliska is offline   Reply With Quote
Old 09-02-2009, 02:44 PM   #4
SmallBlockNova
SmallBlockNova's Avatar
Send a message via AIM to SmallBlockNova
What tires do you have?? Are they VW type no-name 165r15 radials? If so...
Mine have taken lots of abuse...Been 130 on them, numerous wheelstands, slamming down, not to mention countless street miles..
SmallBlockNova is offline   Reply With Quote
Old 09-02-2009, 03:35 PM   #5
blasttime
blasttime's Avatar
Smile Re: Front Runner Tires - which brand?
moroso ds2 very happy.
blasttime is offline   Reply With Quote
Old 09-02-2009, 04:02 PM   #6
treessavoy
Liked 4 Times in 4 Posts
Moroso, they'll dry rot before you can wear them out. Never had a balance problem and they always ran straight.
Jim
Jim Rountree
Old 09-02-2009, 04:07 PM   #7
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Moroso Drag Specials here too.7.10x15
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 09-03-2009, 03:07 AM   #8
Rory McNeil
My bracket car has had the same 7.10 Moroso "Drag Specials" for over 10 years, still look like new, and hold air well. My Stocker has 3 different sizes of M/T fronts, they also hold air OK, but they do wear much quicker than the Morosos. The M/T`s are also available in more sizes.
NHRA 6390 STK
M/S 85 Mustang
Old 09-03-2009, 11:44 PM   #9
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Moroso Drag Specials 7.10 x 15".
55 Chevy is offline   Reply With Quote
Old 09-04-2009, 07:27 AM   #10
cad
cad's Avatar
Yes -- they are Kuhmo 165/80r-15 tires. I have been 105 on them without issue, but the new engine should run 115-120mph in the qtr. I figure I had better get a tire on that is rated for the qtr mile.
Sounds like a lot of Moroso tires are out there.
Is there anything bad with the Goodyear front runners?
