Old 08-30-2009, 11:22 PM   #1
GTX JOHN
Liked 2,486 Times in 697 Posts
Default 360 SHORT BLOCK (NL. Rec. Holder)
360 STOCK Eliminator Shortblock current national record holder !! Legal for '74 to 86 conbinations with correct accesories. Will Include correct carb and manifold for your year and a set of the right year heads for your combination. This short block holds record at 1.27 under and has only one pass since set record (Hit the tree literally). If you rering and Hone or sleeve #1 cylinder leaks 8% you should go 1.40 to 1.50 under.Will supply any need tec assistance with purchase. $2,500. Firm try to machine one and buy everything for twice this!
GTX JOHN is online now   Reply With Quote
