Old 08-29-2009, 05:45 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 L78 396-375HP Engine
I have a 396 4 bolt standard bore block casting number 3955272 dated K-4-8 with front pad of T1113JH 19W356950. The block has been cleaned and magged and in excellent original condition with no damage. I have the original set of 3919840 square port heads off of the motor dated J-31-8 and K-4-8 and they have been cleaned and magged. I have the original 3933163 factory aluminum square port intake dated 9-23-68 and it has been cleaned up with no damage to it. I also have the original standard steel 6223 crankshaft, 8 inch harmonic balancer and the original 11 to 1 domed standard factory pistons. The motor has been apart since 1975 and the parts are in excellent overall condition $4500. 330-770-2517
dlv4540 is offline   Reply With Quote
Old 08-29-2009, 03:30 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 1969 L78 396-375HP Engine
Wow! Wish I needed one....
Good luck!
Jeff Lee 7494 D/S '70 AMX
