Old 08-03-2009, 09:41 PM   #1
rayfin
Default 400 sb with 3" stroke?
I always wondered what a 400 sbc with a 283 crank would run like. Anyone ever tried this? I know the 302 sbc (4" x 3") was a hard runner. Just curious.
rayfin is offline   Reply With Quote
Old 08-04-2009, 05:04 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: 400 sb with 3" stroke?
my modified motor is a 4.155 bore and 2.970 stroke. it runs good, but expect a high reving piece. peak power was at 9200rpm.
Mark Markow is offline   Reply With Quote
Old 08-12-2009, 08:41 AM   #3
rayfin
Any videos on youtube?
Old 08-15-2009, 04:33 AM   #4
masracing
If you have a good set of heads on it, it should work very well. I am by no means an expert but I know they have found with the comp motors big bore and short stroke will make more horsepower/cubic inch. It stands to reason bigger piston means you can run bigger valves without shrouding. You have a larger surface area on top of the piston which when you think of the laws of hydraulics would generate more force on the piston for the same cylinder pressure. The catch to it is having a good enough flowing cylinder head to efficiently fill that large bore at high RPM.
Just my understanding of it so take it for what its worth.
B.J. Masiello
masracing is offline   Reply With Quote
Old 08-25-2009, 01:07 PM   #5
rayfin
Thank you for the feedback guys.
Old 10-26-2009, 08:22 PM   #6
Bill Baer
Talking Re: 400 sb with 3" stroke?
B.J. Masiello
Mr. Masiello pretty much right on target but if your bracket racing especially if your using an auto trans, a longer stroke/bigger motor will make the same or more power, more torque and at a lower RPM range and it's torque that moves the car.
It could be fun if you had a tunnel ram, Titanium valves and a five speed! (At least until you break a couple of valve springs!)
