Old 07-31-2009, 11:56 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Default Master Cylinder brake fluid leaks out fill caps
Wildwood master cylinder has splashed/leaked out brake fluid around both fill caps........really looks good on custom paint job at firewall.......is this a freak thing or has anyone ever heard of this ?????
Rusty Davenport is offline   Reply With Quote
Old 07-31-2009, 04:10 PM   #2
Tom Turner
Default Re: Master Cylinder brake fluid leaks out fill caps
Not a freak thing at all. If it's the Mopar style master, that's a common deal. I cured mine by running the level down about an inch. I think the problem is the splash shield on the bottom of the caps; poor design. TT
Tom Turner is offline   Reply With Quote
Old 07-31-2009, 05:00 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i have the same deal with seapage out of the caps,run the fluid lower ,,one thing that seams to contribute the problem is the the amount of brake presure applied,,when i stage my car i have about 900-1050 psi and letting off the brake rushes the fluid back to the master and splashes back ,,i have to wipe off the master every now and then gmonde
Old 07-31-2009, 08:38 PM   #4
TOP GUN
Seen it a lot with my strange mopar mc. File top ofthreads with aflat file to git rid of casting flaw. Add 1 or 2 layers of duct tape between rubber gasket and lids to titen twist on pressure.
nitro joes TOP GUN 3 years straight
mark young
TOP GUN is offline   Reply With Quote
Old 07-31-2009, 11:35 PM   #5
Ronald Urquhart
Liked 77 Times in 39 Posts
Smile Re: Master Cylinder brake fluid leaks out fill caps
Try taking and old plastic antifreeze jug or oil bottle, take the cap from your master cyl pop out the rubber gasket use it as a template cut out a couple of circles use them as shims between the rubber gasket and cap. I did this a couple of years ago hasn't leaked since.
Ronald Urquhart is offline   Reply With Quote
Old 08-05-2009, 12:22 AM   #6
Moparteacher
The seal on the caps must seal the fluid from the atmosphere. The vent in the cap directs atmospheric pressure to the top side of the seal.
Brake fluid is extremely hydroscopic in that it obsorbs moisture from the air, hence the seal.
If the fluid is pushing past the seal, and the seal is good, then the fluid may be contaminated. Moisture and oxygen in the fluid will expand with heat and push past the seal. Contamination will also lower the boiling point of the fluid.
Consider flushing the system and replacing with new fluid from a previously unopened container.
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 08-05-2009, 05:37 AM   #7
Gary Tackett
Liked 13 Times in 3 Posts
I have a Lamb and have never had an issue. Take a look at the rubber boots in the cap. If they are protruding out, you have air in your system. That rubber nipple in the cap will take up space in the master and force the fluid out.
Good Luck
Gary Tackett is offline   Reply With Quote
Old 08-05-2009, 09:52 AM   #8
lgvoiles
lgvoiles's Avatar
Same leaking problem with mine also, I re-bleed my capilers then filled
the level about 3/4" lower than before, seems not to be leaking now.
lgvoiles is offline   Reply With Quote
