Old 07-23-2009, 11:31 AM   #1
Ben Kallies
Default Stock Eliminator - Any Valve Job?
I have a question regarding the new valve job rule that states: Any valve job allowed. Can I assume that this rule allows for back-cutting the valve to match the angles cut in the head? For instance, if I choose to do a 5-angle valve job instead of the old 3-angle, I would need to cut to the valve to match. Is this allowed? I didn't see it mentioned specifically in the rule book. Thank you.
-Ben
Ben Kallies is offline   Reply With Quote
