Old 07-22-2009, 12:57 PM   #1
drace69
Default Can you Patch a hole in a slick?
Has anyone patched a hole in a racing slick and had it hold?
What did you use just a regular tire patch or ??
I see I must have picked up something in one of mine.
thanks for the response.
drace69 is offline   Reply With Quote
Old 07-22-2009, 01:16 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Can you Patch a hole in a slick?
yes, you can use a regular passenger car tire "plug" [the rope looking, sticky type] it will be fine. I picked up a large screw one night going into the semi's - thought I was done for the night. The fellow parked next to me plugged and I won the race. Then put another 60 runs on that tire before replacing it.
Larry Woodfin 471W
Old 07-22-2009, 03:47 PM   #3
Signman
Liked 269 Times in 99 Posts
If you can get the natural rubber plugs even better.
I keep them in my trailer. Have plugged slick before going to lanes for a run. Do a good burnout and you will have a hard time finding where the plug was. They become part part of the tire and won't leak in the future as a rope plug may.
Old 07-22-2009, 04:38 PM   #4
THE LEGEND
I don't think I have a tire without a plug. Front or back.
Plug it you will be fine.
Chip
THE LEGEND is offline   Reply With Quote
Old 07-23-2009, 09:36 PM   #5
drace69
Sounds good - thanks for the input guys!!
