Old 07-20-2009, 08:29 PM   #1
want2be
Cool on a 69 camaro do you
solid body bushings-do you use the stock height on do you trim them down, leave them at the orginal thickness?
front tires/wheels-left to right-do they match in size or is there some "trick" to gain a little stagger
any tricks of the trade you wish to share on getting stagger
thanks in advance
want2be is offline   Reply With Quote
Old 07-21-2009, 10:58 AM   #2
Lapeeracing
Send a message via AIM to Lapeeracing
Smile Re: on a 69 camaro do you
If you thin the bushings,you will also lose clearance from the hood to carb-not the way to go -in my opinion.
Lapeeracing is offline   Reply With Quote
