Old 07-12-2009, 07:47 PM   #1
Ted Barnes
Ted Barnes's Avatar
Default Acceptable starter voltage drop?
I'm wondering if anyone can tell me what is acceptable for voltage drop from the battery to the starter while it's cranking? I've been chasing gremlins all season and the drop in my car is 1.1 volts. I heard that anything over 0.5 volts is trouble but I'm curious if anyone's measured this?
Thanks
Ted Barnes 1511 HR
Ted Barnes is offline   Reply With Quote
Old 07-13-2009, 06:24 AM   #2
john anderika
Default Re: Acceptable starter voltage drop?
You must have a min. of 10.5 volts at the starter under crank. The .5 volt is correct for voltage drop
john anderika is offline   Reply With Quote
Old 07-13-2009, 11:10 AM   #3
ChevyII
ChevyII's Avatar
Liked 2 Times in 2 Posts
Hi Ted,
Sounds like the TNT deal has taken off. Kudos to you! We may have to make a trip to Ontario in 2010 with the car and jump in.
I saw your note and thought I might pipe in. How old are your batteries and what are you using?
What are you reading at the batteries?
Mike Ferstl
SG SR 6091
ChevyII is offline   Reply With Quote
Old 07-18-2009, 06:07 AM   #4
Ted Barnes
Ted Barnes's Avatar
Originally Posted by ChevyII View Post
Hi Ted,
Mike Ferstl
SG SR 6091
That's the mystery. The batteries are only 18 months old...and test ok....but I'm going to throw them away anyway and replace the main cable.
Thanks Mike
Ted
Ted Barnes 1511 HR
