07-06-2009, 03:56 PM | #1 |
95 s10 front spring help needed
My dad usually posts on here and i searched all over and couldn't find what I was looking for so here it goes. I have a 95 s10 with stock front suspension but it has a rack and pinion. The truck has a BBC and is pretty nose heavy (1900 lbs on the front 62% of 3060). Has comp engineering 90/10s. It doesn't transfer weight very well even when the track is good. It works pretty descent (1.33 60 ft) when the track is good but if the track starts going away any it loses a bunch of 60ft. It has stock springs on it now so which springs should I look at getting?
Thanks for any help Josh |
07-07-2009, 12:26 AM | #2 |
Liked 4 Times in 1 Post
Re: 95 s10 front spring help needed
josh, i would at least go to a big block spring from a chevelle to start, but i would go with a moroso spring. you already know your front end weight, go to jegs or summit online or call and order those weight spec. springs. rick.
