Old 06-22-2009, 03:47 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default Trailer wheel bearing question?
How often do you repack the wheel bearings on your car trailer?
Base it on time or milage?
I've owned my open car trailer for about 2 years, but only have
hauled it about 6000 miles.
I've heard that on a travel or enclosed car trailer that even if not
towed, the wind will still cause the trailer to move around on the
bearings causing wear while parked.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 06-22-2009, 05:27 PM   #2
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Default Re: Trailer wheel bearing question?
Phil, there are many different combinations of trailers,axles,wheels,and tires that would require different maintenance conciderations. I would do the bearings now, and note the conditions of the bearing, grease and seal. That will provide some insight as to how often you should inspect those components. Doing this will also allow an inspection of the brake shoes, springs, retainers, magnets, and related hardware. Procure the bearing seals before you start the job (they're cheap). Do the maintenance....go down the road.....have fun! I saw a good thread on here about trailer tires recently....read it !
Wade Mahaffey is offline   Reply With Quote
Old 06-22-2009, 05:29 PM   #3
scott helms
scott helms's Avatar
every year or 10,000 miles witch ever comes first,while sitting grease get dry or melts depending on climate.I do it at the start of every season
scott helms is offline   Reply With Quote
Old 06-22-2009, 06:59 PM   #4
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
one thing you mite want to invest in is a set of bearing buddys,they have a grease fitting that allows you to use a grease gun to pump grease in this way you can know there is grease in there ,still need to pull them apart once in a while to check things out gmonde
Old 06-23-2009, 09:50 AM   #5
Bruce Schoenbaechler
Ditto on the bearing buddies...had them on my enclosed trailer for years, never had any problems with bearing failure. I do recommend that after they are seated in you use some silicone around the bearing buddy and the hub junction as a safeguard. I have seen the bearing buddies work loose and come out.
SCHOENY
Bruce Schoenbaechler is offline   Reply With Quote
Old 06-23-2009, 10:12 AM   #6
Phillip marvetz
Phillip marvetz's Avatar
You should only use the bearing buddies on axles that are meant to use them, They have a small hole drilled in the axle shaft to let the excess grease escape. If you dont have that relief hole you can push the seal out of the drum and then you have a mess and alot of dirt in your bearings.
Old 06-23-2009, 10:15 AM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Trailer wheel bearing question?
* Be careful that you don't over-lube the bearing buddies. Otherwise the grease will seep into the drum and "lube" the brake shoes.
* There was an obvious increase in bearing life when I switched from conventional HD bearing grease to synthetic. (I use Amsoil - www.thelubepage.com
* Manually adjusting the trailer brakes on a regular basis will extend their life also.
LOCOMOTION Racing
